Configures a captive portal policy and enters its configuration mode. Once created and configured, use the captive portal policy in the WLAN context, and in the device/profile contexts of the access point or controller hosting the captive portal server.
A captive portal provides secure access using a standard Web browser. Captive portals provide authenticated access by capturing and re-directing a wireless user's Web browser session to a captive portal login page where the user must enter valid credentials to access to the wireless network. Once logged into the captive portal, additional Acknowledgment, Agreement, Welcome, No Service, and Fail pages provides you options to customize the screen flow and user appearance.
Captive portals are recommended for providing guests or visitors authenticated access to network resources when 802.1X EAP is not a viable option. Captive portal authentication does not provide end-user data encryption, but it can be used with static WEP, WPA-PSK or WPA2-PSK encryption.
Authentication for captive portal access requests is performed using a username and password pair, authenticated by an integrated RADIUS server. Authentication for private network access is conducted either locally on the requesting wireless client, or centrally at a data center.
Captive portals use a Web provisioning tool to create guest user accounts directly on the controller, service platform, or access point. The connection medium defined for the Web connection is either HTTP or HTTPS. Both HTTP and HTTPS use a request and response procedure to disseminate information to and from requesting wireless clients.
captive-portal <CAPTIVE-PORTAL-NAME>
<CAPTIVE-PORTAL-NAME> |
Specify the captive portal name. If a captive portal with the specified name does not exist, it is created. |
nx9500-6C8809(config)#captive-portal test nx9500-6C8809(config-captive-portal-test)#? Captive Portal Mode commands: access-time Allowed access time for the client. Used when there is no session time in radius response access-type Access type of this captive portal accounting Configure how accounting records are created for this captive portal policy bypass Bypass captive portal connection-mode Connection mode for this captive portal custom-auth Custom user information data-limit Enforce data limit for clients frictionless-onboarding Register the client MAC address at ExtremeGuest on redirection inactivity-timeout Inactivity timeout in seconds. If a frame is not received from client for this amount of time, then current session will be removed ipv6 Internet Protocol version 6 (IPv6) localization Configure the FQDN address to get the localization parameters for the client logout-fqdn Configure the FQDN address to logout the session from client no Negate a command or set its defaults oauth OAuth 2.0 authentication configuration php-helper Configure the captive portal to use a server for help with php post-authentication-vlan Configure post authentication vlan for captive portal users radius-vlan-assignment Enable radius vlan assignment for captive portal users redirection Configure connection redirection parameters report-loyalty-application Report customer loyalty application presence in clients server Configure captive portal server parameters simultaneous-users Particular username can only be used by a certain number of MAC addresses at a time terms-agreement User needs to agree for terms and conditions use Set setting to use webpage Configure captive portal webpage parameters webpage-auto-upload Enable automatic upload of internal and advanced webpages webpage-location The location of the webpages to be used for authentication. These pages can either be hosted on the system or on an external web server. welcome-back Welcome back page settings clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-captive-portal-test)#
no |
Removes an existing captive portal |
